Battery indicator light is now red when charging - lost battery life
This is a discussion on Battery indicator light is now red when charging - lost battery life within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Before, it was orange while charging and would turn green when it got to 90%. The other day, just out of the blue, I plugged ...
Thread: Battery indicator light is now red when charging - lost battery life
    Junior Member ukwildcats11's Avatar
    The other day, just out of the blue, I plugged in my N1 to charge, and the indicator light was red. Now, the light stays red while charging until I reach 90% and then the light just goes off.
    Ever since this has happened I have found a dramatic loss in battery life. I will go to bed with a 100% charge, and everything off(wifi, gps, etc), and about 7 hours later it'll be about 50%. Before all this happened that would have been about 75% or so.
    I bought a new OEM N1 battery and everything is exactly the same with the new battery.
    Help/Suggestions? TIA
    14 times
    Not much luck in finding a solution to this. Have you tried calibrating your battery? Or a Factory Data Reset?
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    I don't think I know how to calibrate the battery.
    I've thought about a factory reset, but I really want that to be a last resort.
    14 times
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    Android Lurker maris's Avatar
    That doesn't sound good, especially since you have the same problem with a new battery.
    Have you checked your charging cord? My cat loves to bite my cord for some reason and I have to take care when charging it. Hopefully you just have a damaged cord.
a white led light is flashing on my chromebook
chromebook charging light red
chromebook charging light turns red
chromebook light red
chromebook manuals red indicator light
chromebook red charge light
lihht on cromebook turns red while charging indicates
red light when chromebook is charged
samsung chromebook charge light red
samsung chromebook has red light where charger is plugged in
samsung chromebook red light
what does it mean when charge lighton samsung is red
what does the red led light mean on a samsung chromebook
why is my battery indicator light orange on my phone
why is red light flashing on chromebook
