3GP& JPEGS not recognised on N1
This is a discussion on 3GP& JPEGS not recognised on N1 within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I have taken several photographs and some videos using the 'camera' widget that came with the phone out the box.... It writes them to the ...
Thread: 3GP& JPEGS not recognised on N1
    Junior Member Rogue666's Avatar
    Unhappy 3GP& JPEGS not recognised on N1
    It writes them to the sd card to the DCIM\Camera path
    The pics are labelled '.jpg' and the vids '.3gp'
    The size of them range from 800k for some pics to 22000k for video.
    I can, and have, copied them onto my pc and they retain size,name and type..
    so far so good.. BUT
    I CANNOT display them on the phone however.. neither pic or vid..
    I've used the camera viewer(the one I took the stuff with), arcmedia, express gallery etc...
    similarly for the copied files on the pc i've used everything from the bog standard windows player to realplayer, gomplayer, 3gpplayer , i've tried 3gpconverters and i've got them all to search for the 'correct codecs' without success..
    I've copied them to different directories on the phone and I've reinstalled camera and gallery, i've rebooted etc.. still no joy.
    when in 'gallery' and I choose camera folder it shows me the place holders but they are blank, when I pick a place holder just a black screen.. the mad thing is i viewed these things on 'camera' view shortly after taking them but a day later.. NADA!
    when I try to upload an example jpeg to the forum it says;
    "IMG_20101029_210840.jpg:
    This is not a valid image file."
    Any thoughts Anyone? Desperate.. they're wedding pics.. of course
    14 times
    I am not familiar with the "Camera Widget". It came preinstalled on the phone?
    Are you rooted or stock?
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Some more details would definitely be in order.
    Phone, Operating system, etc. etc.
    A sample file might be very helpful as well.
    hi..
    thnks for your help..
    right then... i'm nexus one stock & running froyo (android2.2)
    16gb sd card
    can't upload any of example pics to forum as the forum says
    is there a email I can send an example to?
    The camera widget i referred to is the icon that was on the screen(pre-installed) when I first turned it on... a black circle with the word 'camera' written underneath it.
    i'm unlocked and with O2
    cheers
3gp&
