Weather App Info display wrong?
This is a discussion on Weather App Info display wrong? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Has anybody figured this out yet? I'm having the exact same problem but I'm rooted with Cyanogen 6....
Results 11 to 15 of 15
Thread: Weather App Info display wrong?
    Junior Member savagemoogle's Avatar
    Android Lurker maris's Avatar
    I just noticed this in the last couple of days. While beautiful widgets shows my location and weather correctly as I relocate, the built-in news/weather app is crazy. It shows me in another state in a city I never heard of. So very strange. While the weather is showing, I can tap menu/refresh and it will then load my correct location, but the little timer bar thing is as OP says, only shows one hour and it's the previous hour.
    My display on the weather info screen has now fixed itself. Where, for a while, it was the previous hour and in reverse, it is now showing the next 24 from left to right.
    Regarding your location, have you checked the settings (see the menu button)? There are two options that concern this. Under weather settings, you can tell the weather app which location to use. Then there is a general option for refresh settings where you can tell it how often you want it to update the weather.
    Quote Originally Posted by FlyingsCool View Post
    Well, mine fixed itself, too. However, when I checked my settings I realized somehow the auto refresh had unchecked. I reset it so all should be fine. I let it find my location, so not sure why that went crazy, but whatever happened has settled itself.
    Android Lurker iPeck's Avatar
    Laval, Qc
    I no longer use it. And yeah, I was experiencing the same.
    Beautiful Widgets weather widget is the best...
  1. Set CPU
    Last Post: 12-21-2010, 11:17 AM
  2. Epic 4G Rom Discussions
    Last Post: 11-28-2010, 09:04 AM
4s weather widget stuck on wrong date
accuweather showing incorrect time android
android ap to show date current location and termperature
android displays wrong temp
android weater app wrong
android weather app shows the wrong time
android weather app wrong temperature
galaxy s4 weather app shows wrong time
nexus mobile weather app shows wrong location
samsung watch showing wrong temperature
weather channel app wrong temperature
why is my accurate temperature wrong on my s4 samsung
wrong city weather on samsung s4 cell phone
wrong day displayed on iphone 4 weather app
wrong desk clock location on samsung s4
