Weather App Info display wrong?
This is a discussion on Weather App Info display wrong? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Anyone else having an issue with the Android weather app? I was happy with the weather app. If I clicked on the weather widget next ...
Results 1 to 10 of 15
Thread: Weather App Info display wrong?
    I was happy with the weather app. If I clicked on the weather widget next to the news and hit the "i" in the top right, it showed the predicted temperature and moisture for the next 24 hours, and you could drag a bar across to show the time for the graph as you dragged the bar across.
    Now, however, it only shows this for about one hour's time for 1 hour previous to the current time, and the time drags in reverse left to right, i.e. it starts at 7:00 am and ends at 6:00 am when the actual time is 7:40 am.
    Any ideas for how to fix this? I've tried refreshing the weather, deleting the widget and creating a new one, and rebooting the phone to no avail.
    Is there any chance this is related to the fact that I recently replaced my SD card with a 16 GB one? I have noticed that some of my ringtone assignments have been messed up, pointing to different songs. I assume this is because I used a PC to copy the data from one SD card to another, which I imagine screwed up some index which relied on file position in a table to determine which file to use. I notice that before, the ringtones I added were intermixed alphabettically with the default ringtones, now the phone lists the default ringtones first, and then the ones I added. Not a big deal to me, I just had to go through and reassign my ringtones.
    But I really want to get this weather widget fixed.
    Junior Member cachiama's Avatar
    Same issue here, I also cleared the widgets app data and cache
    did you reboot after claearing caches
    may try uninstalling and reinstalling app
    [SIGPIC][/SIGPIC]
    San Francisco Giants
    did reboot, but will not uninstall as I have the missing apps issue
    Quote Originally Posted by cachiama View Post
    Missing app issue I am not aware of an issue like this can you elaborate a little more?
    I also have a question on the weather app although itís a not the same one. I just wanted to know if there is a way to set it to Celsius instead of Fahrenheit cause I don`t use Fahrenheit I use Celsius.
    For Celsius go to the app, settings > weather settings => use metric should be ticked
    By missing apps I meant copy protected apps such as Google maps and earth not found in the market and thus not updateable
    Thank you for the tip on the Celsius thing.
    As for the missing app issue I think I herd of this once. Have you tried anything to fix it?
    As for your problem since you won`t uninstall the only other thing I can think of is a factory reset.
    As far as I know, you can't uninstall the News/Weather app, it is part of the OS, and has not been updated in any way. You can remove the widget without issue, but you cannot remove it from the phone (unless you are rooted, I am not).
    You won't see the app in applications because it is an OS app. To see the app, you must select "All" at the top of the settings/applications/manage applications menu.
    I tried to fix the missing apps issue but there doesn't seem to be a fix without rooting. The issue is common with unlocked phones.
    I own a nexus one, I bought a developer subscription yesterday as nexus one with developer account should be able to see hidden apps (found on google dev phones page) but the attempt was useless.
    Root then, it's so easy, and very rewarding! :-)
  1. Set CPU
    Last Post: 12-21-2010, 10:17 AM
  2. Epic 4G Rom Discussions
    Last Post: 11-28-2010, 08:04 AM
4s weather widget stuck on wrong date
accuweather displays wrong time
accuweather showing incorrect time android
android ap to show date current location and termperature
android displays wrong temp
android weater app wrong
android weather app shows the wrong time
android weather app wrong temperature
nexus mobile weather app shows wrong location
samsung phone always show wrong temperature
samsung watch showing wrong temperature
weather channel app wrong temperature
why is my accurate temperature wrong on my s4 samsung
wrong city weather on samsung s4 cell phone
wrong day displayed on iphone 4 weather app
