Using camera flash makes phone stop working
This is a discussion on Using camera flash makes phone stop working within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Whenever I use the flash on the camera the N1 dies. I then need to remove and reinsert battery to use it. Im running froyo ...
Results 1 to 8 of 8
Thread: Using camera flash makes phone stop working
    Junior Member methosmen's Avatar
    Im running froyo now and the issue has been present on the last two android versions as well.
    Anyone familiar with this issue?
    May be hardware...
    Try deleting the camera data, and see if it helps...
    Tried to delete data with MENU>Settings>Applications>Manage applications>MENU>Filter>All>Camera then "Clear data". Using flash still triggers freeze.
    Hope I'm wrong, but I think it may be a hardware issue... :-(
    Thanks. Don't have the receipt, guess I can live with this.
    Like I said, I hope I'm wrong.
    Try asking on xda...
    Have you tried a system wipe?
    Well if this doesn’t fix it then I think it is hardware its almost sure its hardware. Although maybe flashing a custom ROM might help but since you said it has been like that since eclair I dough it.
