Warning: Upgrade doesn't work
This is a discussion on Warning: Upgrade doesn't work within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; My Nexus One told me this morning (2010-11-23) that I had an upgrade to install in a two step installation. After the upgrade I ended ...
Thread: Warning: Upgrade doesn't work
    Junior Member Kjell's Avatar
    After the upgrade I ended up with:
    * My icons, ring tone, background and accounts were gone. It seemed to be like a new phone with welcome messages.
    * Most applications crashes - including Listen and K9-mail.
    * Most applications were still there.
    * Dial history was gone of course.
    It seems like most things stored in phone was gone or something (only one of my music playlist is gone).
    I've started to reconfigure my life again.
    This is just a warning to those thinking about upgrading the phone at the moment.
    Update: The crashed applications are fixed by uninstalling and reinstalling.
    Lot of work, but it works. Beware of non-backupped data...
    Senior Member Nobby's Avatar
    Sorry for your loss of data and thank you for warning the rest of us hopefully people will now backup before updating.
    NEXUS ONE
    11.02.2010 - SuperBoot Rooted
    NOTION INK ADAM
    02.05.2011 - BEAST 2.2
    14 times
    So then the Upgrade ota did work? You just lost data i see.
    Always recommended that you backup everything you can before upgrading
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Junior Member errolc8_nexusone's Avatar
    I am so annoyd received message to update, this thing has killed my phone everything hasd gone !!
    At a lost as to where to start, I have lost my Network connecton even olost Netyrk connection
    Has anything as severe happened to anyone else following update?
    Help!
    Help
    14 times
    thats Odd.
    Have you tried a Factory Data Reset? Might as well give it a go since all your stuff was wiped anyway.
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    Junior Member dveldt's Avatar
    No problems to report here. Took a few minutes longer to boot after the second part of the update, but once I was up and running everything stayed the same.
