I Got a CHINESE Nexus One!?!?! Help
This is a discussion on I Got a CHINESE Nexus One!?!?! Help within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello everybody, I bought a used nexus one yesterday and it seems that the phone is only encoding big5 and gb2134 (chinese) . all the ...
Thread: I Got a CHINESE Nexus One!?!?! Help
    Junior Member sacha's Avatar
    Arrow I Got a CHINESE Nexus One!?!?! Help
    Hello everybody, I bought a used nexus one yesterday and it seems that the phone is only encoding big5 and gb2134 (chinese) . all the apps are in chinese. just the dashboard is in english. help me , how can i have it all in english!!?? Its an enigma for me.
    Press your Menu button right above the track ball, then press the settings button (lower right hand circular icon). Next scroll the screen down to the 10th item listed which should have a box with an A inside it and select it. Next scroll down 17 selections and select and that is English (United States) and that should get you back. From that point you should be able to read your phone and items in it. Hope that helps.
    Well be dashboard do you mean the home screen if so when you go to the settings is it in English? If so then it is the phone that is in Chinese if not then your apps are Chinese.
    UK
    8 times
    Nd1razor
    One your in the home screen, (press the house icon) follow these instructions.
    -press the menu button (led lots of lines)
    -Hit settings (looks kinda like a volume knob/gear cog)
    -Scroll down and hit keyboards and language (The icon is a square with the letter A in it)
    -hit the first option
    -Pick english (2-4 option on my N1)
    Hope this helps!
    -Fury
