Wi-Fi FAIL = HTC hardware issue??
This is a discussion on Wi-Fi FAIL = HTC hardware issue?? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi, After about a year, my Wi-fi has stopped working. When I turn it on, and it begins a search for a network (in Settings) ...
Thread: Wi-Fi FAIL = HTC hardware issue??
    Junior Member fahuser's Avatar
    Exclamation Wi-Fi FAIL = HTC hardware issue??
    Hi,
    After about a year, my Wi-fi has stopped working. When I turn it on, and it begins a search for a network (in Settings) the search hangs with this message:
    (in process com. android.settings) is not responding
    I can FC or Wait or Report.
    I have Googled this problem, and all comments agree that it's a HTC hardware issue.
    Is it? Can you confirm this problem? Any suggestions?
    If it worked at some point then it is either your hardware that got damaged or its a software issue. Unfortunately as far as restoring it I say your two only options are call htc and factory reset (not necessarily in that order).
