Nexus One issue.on 2.2.1
This is a discussion on Nexus One issue.on 2.2.1 within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello, Since the day I updated my Nexus One to 2.2.1 OTA, I have been experienced a pain issue. About 1/3 of my apps are ...
Thread: Nexus One issue.on 2.2.1
    Senior Member wingod_nexusone's Avatar
    Hello,
    Since the day I updated my Nexus One to 2.2.1 OTA, I have been experienced a pain issue. About 1/3 of my apps are always pop up with Force Close problem. It also always hang with then turn into black screen (the 4 buttons below is light on), power button not working, then i put it on the table and wait, it reatart itself....
    What can i do with this case? anyone having the issue with 2.2.1 ?
    p.s. I just talked with my phone, by the time i want to cut my line, my N1 screen went black, all buttons not working. I could still hear the person in the phone saying "please cut the line", then after 2 mins, my N1 restarted itself
    Please join Dropbox here: Register :nexusx:
    Never heard of that but I would just factory reset if I were you.
    I just had my hard reset 2 weeks before
    Well then there are two things you could do 1 call htc and ask for a fix 2 try rooting and custom ROM but since you signature is refuse to root I think you are going to go with the first one.
    Junior Member Jonesn's Avatar
    I also have a similar issue. 99% of my Apps force close, the phone did a reset so I had to resync to accounts (which needed re-entering) to retrieve my contacts and SMS's etc
    Also, no other settings ie, widgets on homescreens, background etc.
    Not a very well tested update in my opinion. This needs a fix.
    Any further ideas? My phone is as per brought from a shop (ie. not unlocked etc)
