Call screen timesout when on speakerphone
This is a discussion on Call screen timesout when on speakerphone within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Device: Nexus One Carrier: O2 Country / Language:Ireland English OS / Browser / build number (if applicable):Froyo I use my phone for work conference calls. ...
Thread: Call screen timesout when on speakerphone
    Junior Member keltchick's Avatar
    Device: Nexus One
    Carrier: O2
    I use my phone for work conference calls. The problem is if I put a call on speaker and then want to say put phone on or off mute the screen has timed out and I can't do anything if i wave it around nothing happens and pressing the power button just drops the call . this is really frustrating any solution????
    14 times
    Extended Controls widget has a widget button that can keep your screen on as long as you want.
    Extended Controls - Cyrket
    Does that help?
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    installing now, we shall see. Thanks for the suggestion
    got the solution its Settings > Accessibility > Power button ends call (<--- UNCHECK THIS) in case anyone else every searches for this issue :-)
    Quote Originally Posted by keltchick View Post
    Aren't you super helpful and friendly Jonnie
    I do what I can
