Technical Problem ???
This is a discussion on Technical Problem ??? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi all, iam having problem with my nexus1 button on top. I have to apply huge pressure and sometimes many times to get the phone ...
Thread: Technical Problem ???
    Junior Member bryann07's Avatar
    Unhappy Technical Problem ???
    Hi all, iam having problem with my nexus1 button on top. I have to apply huge pressure and sometimes many times to get the phone to active mode. is this an major problem??? kindly advise.
    Senior Member Nobby's Avatar
    Hi Bryann,
    Firstly welcome to the site
    The problem you are having is very well known on these forums and in some cases it is workable if you have no warranty, other times its a case of downloading special launcher apps that allow the device to wake using the Trackball.
    You could try a few things to find the problem so try the following first;
    * open the phone up and give it a good clean
    * try pressing the button down in different areas just in case its a split rod
    If you still suffer from the button being stiff then contact HTC repair and have it repaired, if you cant then try and download a launcher app that allows for trackball wake and maybe a sleep widget that will lock the phone and in turn bypassing the power button altogether (unless powered off)
    NEXUS ONE
    11.02.2010 - SuperBoot Rooted
    NOTION INK ADAM
    02.05.2011 - BEAST 2.2
