Something trembles inside when shaking my Nexus One
This is a discussion on Something trembles inside when shaking my Nexus One within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Originally Posted by d4ni3l Hi guys, I started to notice a tiny tremble sound when I shake my device Don't shake it then :rofl3:...
Results 11 to 17 of 17
Thread: Something trembles inside when shaking my Nexus One
    Senior Member Iggy82's Avatar
    Quote Originally Posted by d4ni3l View Post
    Hi guys,
    Nothing is perfect, but we must not lose faith in perfection. If we did, everything would be a whole lot worse than it is now!
    Member d4ni3l's Avatar
    if you have nothing to say you'd better roll on the floor quietly =)
    Quote Originally Posted by snowy View Post
    I don't think the Nexus1 has an accelerometer, sounds like the vibrator motor making the noise.
    If you have ever opened up a fone all the vibrator is is 2 small weights being spun round
    O-.-O spins round the dot in the middle
    Rob
    Yes the nexus one has an accelerometer an accelerometer is what lets it know how it is oriented as in that is what tells it that you are holding it sideways so the screen turns. As for the vibrator motor I know but it is not suppose to rattle when you shack that phone.
    Junior Member snowy's Avatar
    So what does the 3 point gyro do ??
    uh as far as I know the nexus one doesn’t have a gyroscope cause I pretty much memorised the spec sheet from Google and just did a search to make sure and I don`t think the nexus one has a gyroscope.
    So in that case nothing.
    Sorry I was reffering to the one in the S,
    ****Wrong Group Alert****
    Laters Rob
    Member phunds's Avatar
    Rob
    agree, mine has been doin this since day one. Its normal.
    -Phunds
    :nexusx: Nexus One owner since: January 11th, 2010
    :nexusx: Rooted! Android 2.2 FROYO CM6.1 RC
    phundsblog.blogspot.com | twitter.com/phunds | facebook.com/phunds
