Nexus one connection to PC
This is a discussion on Nexus one connection to PC within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi, I am not able to connect my nextus one to PC. I did not get CD with this phone but I have intalled android ...
Results 1 to 10 of 18
Thread: Nexus one connection to PC
    Junior Member arvindkumarbhardwaj's Avatar
    Hi,
    I am not able to connect my nextus one to PC. I did not get CD with this phone but I have intalled android SDK. I am able to rechrage my phone from my PC though usb cable and using windwos 7.
    I have chanhed mode also USD debugging in connect to pc settings..
    Help me please what else I have to check to connect. I have to take back of my data on pc.
    Android Lurker iPeck's Avatar
    Laval, Qc
    Thats one of the reasons why i have a mac lol best of luck
    __________________
    Sent from my Nexus One via Tapatalk
    Need to install the drivers. Easiest way is to install PDAnet.
    What do you need to connect and backup I mean all that you can backup is on the SD card unless you are rooted and in that case you can just download titanium backup and backup to the SD card. So what do you need to connect it for?
    Junior Member 1hen2ducks's Avatar
    I can't root my phone running 2.3.4
    Phone will not connect to computer, any computer.
    You don't need to connect to a PC to root. You can download the passimg file directly to your phone and run it. You can then download Universal Androot and run that from the phone...
    How are you trying to connect to a PC, and what errors are you seeing?
    I'm nor seeing any errors, I'm not seening N1 on my computer screen.
    I need to do all of this using sd card installs I guess.
    Is there a good instructional link. I'd prefer Cyanogen CM7. I'll get there that way,
    Can I install the CM7 the same way I did my Nook Color ? I'm really dumb about this s***
    Thanks
    Nook is a kinda different monster, because it can boot from SD. I'm not sure which method you used, but lets just focus on the N1...
    Taking things a step at a time, the first thing you need to do is revert to an earlier version of android. The method uses a file named passimg, which is why people call it the passimg method. Are you familiar with it?
    Whatever comes in a downloadable APK will be best for me. I'm getting tired of this.
    Passimg, can that boot from SD ? Can it be downloaded via QR or equal ?
    Passimg method basically involves placing a could on your SD, and booting into hboot. Your phone should do the rest of the work...
    Follow the restore guide here...
    http://www.nexusoneforum.net/forum/n...html#post98568
can i connect my nexus 7 to my pc
htc nexus one connect computer
nexus 1 connect to pc
nexus one connect to pc
