apps keep saying "installing" help needed! Thanks
This is a discussion on apps keep saying "installing" help needed! Thanks within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Originally Posted by rugmankc You need to reboot into recovery right after repartitioning. Or there may be issues. If you didn't do that, I would ...
Results 11 to 18 of 18
Thread: apps keep saying "installing" help needed! Thanks
    Junior Member Nexus2010's Avatar
    Quote Originally Posted by rugmankc View Post
    If you didn't do that, I would redo all and reboot into recovery before wiping/flashing anything.
    Bu sd card first!
    I did all mine thru Rom Mgr Paid version 2.5.0.7. It did an ext3 as confirmed by Mini Partition Tool Wizard.
    1gb/zero swap
    ken
    I followed your instructions and the same problem exist. I couldn't use Rom Mgr because I can't install or uninstall anything.
    Well, lets try a little experiment then. Use Root Explorer, and see if you can copy the apk from your SD to your /cache folder on the phone. See if it will install from there...
    Did you do all the partitioning etc on your old 8g card, also?
    Where is root explorer? I don't see anything on my phone that says root explorer, of-course if its an app I can't install it.
    My old sd card was manually partitioned on my old g1.
    Someone on another site says it sounds like it could be an issue with my google account that some others have had. I tried searching but haven't found anything that relates to my problem. People who've been having problems with their google accounts can't access market and email, I'm not having that problem.
    What do you use as a file explorer?
    Can you set up adb on your PC?
    Do you have another SD card you can use?
    I'd like to try and get an app on your phone, and see if that will work.
    I don't think market is the issue, because you can't install from SD, and the market shouldn't effect that...
    ok, i re wiped everything, partitioned again and installed Cyanogen's latest rom, I was hopeful, but after downloading and trying to install Titanium I went through the same "installing problem" The file manager I usually use was Astro, I tried installing that and couldn't.
    One good thing I've noticed is this Cyanogen Rom comes with Rom Manager, spare parts and file manager. I know you mentioned one of those programs before.
    So you can install a complete ROM from SD, but just not apps?
    How about the gapps, did they install from recovery OK?
    i installed gapps from recovery flash from zip. Soon as I went to market to dl a couple of apps, no luck.
    Try unmounting your SD card (menu> settings> SD card & phone storage), and then try the market again.
    i've been trying to dl an app from market for the past hour, i picked a small 1.4mb file and its taking forever, i went back to my old 8gb card, wiped, flashed rod's rom and tried to install from sd with no luck. the only good thing, for some reason when i flashed rod'z latest rom several apps that i had installed weeks back suddenly popped up! so atleast i can use those apps, but still i can't ad any new apps, so frustrating. thanks
    Did you try unmounting your SD, or not?
android app keeps saying installing
app keeos saying installng
appis just keep saying installing
apps saying installing
cant download apps just keeps saying installing
iphone app only says install
kindle fire keeps saying installing
my app keeps saying installing
my apps keep saying installing
why do apps keep saying installing on nook
why do my apps keep saying installing
why does my facebook keep saying installing
why does my phone keep saying its intasalling g
why is my facebook app saying installing
