N1 unable to work after cam ROM
This is a discussion on N1 unable to work after cam ROM within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Originally Posted by toprpm Anyone know what to do? Need help here Sent from my iPhone using Tapatalk You need to try to get the ...
Results 11 to 20 of 30
Thread: N1 unable to work after cam ROM
    14 times
    Quote Originally Posted by toprpm View Post
    Need help here
    You need to try to get the phone to Boot into Recovery and flash a Backup or a Different Rom.
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Junior Member toprpm's Avatar
    Did you try flashing a different ROM, like I suggested, because your phone is not compatible with CM 5.x?
    Any steps or how to guide
    Need help here
    All I can enter is boot menu where recovery press is not working
    I tried I steps in recovering your stock rom and it didn't work
    I'm not sure what you mean by trying the steps to restore stock ROM, can you elaborate?
    Same for recovery press not working - can you elaborate?
    I tried this page steps
    Nexus One/Guides & Tutorials - XDA-Developers
    What exactly did it do when you tried? Did you see anything happen, did you get an error message?
    Same for selecting recovery, what exactly goes wrong? Do you get an error message? Does the screen display the static X logo? Does it show anything?
    I'd like to try and help, but you really need to give me some details...
    No error, just switch off and nothing. it does show the logo X then off thats all
    Sounds like you may flashed an incompatible recovery, also, but it's strange that the unroot/restore didn't work...
    Which hboot version do you have (listed when you boot into hboot)?
    Hboot 0.35.0017
    Hopefully, that's the problem then...
    Do you have adb set up, and do you know how to use it?
