N1 unable to work after cam ROM
This is a discussion on N1 unable to work after cam ROM within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Originally Posted by danger-rat Hopefully, that's the problem then... Do you have adb set up, and do you know how to use it? Sent from ...
Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: N1 unable to work after cam ROM
  1. #21
    Junior Member toprpm's Avatar
    I don't know what is that, of there is a steps I can go easy with.
    Sent from my iPhone using Tapatalk
  2. #22
    Just curious, but, do you read french?
  3. #23
    Nope ,sry
  4. #24
    No problem, I just thought I'd give it a shot...
    Read this thread, and you should be able to get adb working. If not, just ask questions, either in that thread or this...
    You are trying to get a response from the "adb devices" command - your phone may need to be in recovery to do this, even though your screen is blank, your recovery is probably still working.
    http://www.nexusoneforum.net/forum/n...help-os-x.html
  5. #25
    I Give it a shot when back from work.
  6. #26
    OK!
    You're just setting up communication between the phone and computer. You can't do anything wrong, so don't worry about making mistakes...
  7. #27
    OK!
    From the link it seems that I can do it on OSX apple ?
    Or only works on PC
  8. #28
    You can use adb on a mac, but I've no idea how to set it up...?
    On the link for the android sdk, there should be instructions for a mac?
  9. #29
    i TRIED IT on both mac and windows. the software can't see the phone. and through error of dba,,,.dll can't be find.
    they want me to disable application, setting, but thats in phone which i can't enter or use.
  10. #30
    The dll file is on your computer, not the phone, so if you can't find it, you haven't set up the sdk correctly. Read the thread again, and follow the steps to set up the sdk so you can use the "fastboot devices" command...
