N1 unable to work after cam ROM
This is a discussion on N1 unable to work after cam ROM within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Heya, i was using my cam6.1 rc1, so wanted to try the 5.8 or 5.0.08 something like that which was stable. anyway, after installing done. ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: N1 unable to work after cam ROM
    Junior Member toprpm's Avatar
    Heya,
    anyway, after installing done. and reboot, my phone show n1 logo and then nothing. i notice that trackball light white and capacitor buttons light up. using volume i can hear sound. so screen seems not working.
    So help needed to recover or or fix what it cause this.
    14 times
    Did you not make a Nandroid backup?
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    not sure if i did or not,
    14 times
    Have you tried powering off the phone, then while holding the volume down button power back on. This should take you to a menu that lets you get into recovery.
    Are you using Clockwork recovery?
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    How old is your phone? Is it an SLCD model?
    I suspect the phone has the SLCD screen, in which case, the ROM doesn't support it. Probably need to flash a different ROM...
    Also, CM is stable up to 6.1.1, so I'm not sure why you went to 5x for a stable version?
    14 times
    Good Call Danger! Didn't think of that.
    [PHONE] Nexus 4
    [TABLET] Nexus 7
    My phone is 3 weeks old. It worked fine for 2weeks with 6.1 rc rom.
    But read most stable one was 5x so I wanted to check it.
    I did try that many times but nothing happened
    I am using clockwork
    Anyone know what to do?
    Need help here
    Sent from my iPhone using Tapatalk
    Did you try flashing a different ROM, like I suggested, because your phone is not compatible with CM 5.x?
