Videotron N1 Big PROB ! Help...
This is a discussion on Videotron N1 Big PROB ! Help... within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I'm glad you finally got your problem resolved, sorry I was not much help if anything I think I hurt more than anything else. Which ...
Results 11 to 20 of 25
Thread: Videotron N1 Big PROB ! Help...
    I'm glad you finally got your problem resolved, sorry I was not much help if anything I think I hurt more than anything else. Which believe me was really not my intention. As for you question yes you can there is no problem with switching SD cards the ROM is not affected by them so you can do that all you like with no problem.
    Android Lurker iPeck's Avatar
    Laval, Qc
    its alright... i may have done something wrong in the process... wasnt really your fault... but now i am at the point i wanted at start so everythings fine ! just have to wait for GB OTA lol (if any lol )
    ill just root with universal androot and stay that way lmao
    Ok well I'm glad it all worked out and I know for a fact that we will have the gingerbread OTA eventually. It's just a matter of playing the waiting game, although I really hate that game
    Laval, Qc
    hmm says sd might be damaged... just bought it lol.. says i can format but i get an error
    Does it work in your computer?
    Laval, Qc
    yup.... ok i rebooted and now its fine :P waiting game it is.. like you said
    Ok that was simple.
    Don't think universal androot works on 2.2.1...
    Laval, Qc
    hmm well, there are alternatives right ? i may have seen some other apps that do the same... no ?
    (remember no superoneclick, im on mac )
    There are alternatives, but no on phone apps...
