Wifi Hotspot Not Allowing WPA2 PSK
This is a discussion on Wifi Hotspot Not Allowing WPA2 PSK within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; My wifi is only allowing it to be "Open" I can not get it to save a password. Only the "Cancel" button is highlighted. WTF??????????...
Thread: Wifi Hotspot Not Allowing WPA2 PSK
    Junior Member Action123's Avatar
    What version of Android are you running?
    The build is FRG83G. Version 2.2.1 ie, the most recent Froyo OTA.
    Junior Member kfawcett's Avatar
    It's really retarded that it doesn't tell you how long your password must be, but try making a password longer than 8 characters and then you will be able to save WPA2 settings.
  1. More up close and personal of the epic 4g :-)
    Last Post: 08-06-2010, 04:37 AM
android cannot connect to wifi wpa2 psk htc one
android hotspot wpa2 psk
android set wifi hotspot wpa2 psk
android wifi hotspot cannot set wpa psk
android wifi hotspot wpa??
android ??wpa2 psk??
codificare wpa2 psk hotspot android
hotspot issue with oneplus 3 - wpa2 psk
how to add wpa2 psk to htc one hotspot
wifi hotspot not allowing wpa2 psk
wifi hotspot wpa2 android
wpa psk nexus 10
wpa2 psk in nexcus s
wpa2-psk hot spot
wpa2-psk hotspot
