Pattern Lock Screen not working
This is a discussion on Pattern Lock Screen not working within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello, I've been using the Pattern Lock Screen since I got my N1 (6 months ago).. However, for the past 24 hours, it automatically switches ...
Thread: Pattern Lock Screen not working
    Junior Member grenlif's Avatar
    Hello,
    I've been using the Pattern Lock Screen since I got my N1 (6 months ago).. However, for the past 24 hours, it automatically switches back to the default Lock Screen (without patterns to unlock). I went to "Settings>Location & Security>Change screen lock" to set up the Pattern Lock Screen again, worked well for 1 "unlock", and then it automatically switched back to the default Lock Screen!! What is happening? Can anyone help? Thanks much!
    Just 1 more question.. How do you clear the app cache in N1?
    Do you have any apps that might be affecting this like no lock or something similar? If not all I can think of is factory reset.
    As for the clearing cache go to settings-> applications-> manage applications-> then tap the app you want and tap on clear cache.
    I found it what's wrong.. I updated the prey phone tracker and the lock screen works fine now =)
    Thanks!
    Glad you got it resolved.
android pattern lock not working
how to fix pattern lock is not working
pattern screen lock for android not working
