Keypress volume
This is a discussion on Keypress volume within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; So I reset my phone because it was choppy and slow. It works great now but I noticed the keyboard volume is loud. I used ...
Thread: Keypress volume
    Junior Member kris_tal's Avatar
    Keypress volume
    So I reset my phone because it was choppy and slow. It works great now but I noticed the keyboard volume is loud. I used to just lower my ring volume and would make the keyboard volume go down too. But now it won't do it. How can I fix that?
    You could try an app called smart volume free. It enables you to adjust the system volume, which I think is what you are trying to do? You can change the ringer volume, in call volume, notifications, music/media, alarm and system all from the app. You can also lock them, so accidentally pressing vol keys won't change your settings.
    Metro Atlanta
    54 times
    Audio Manager can also do this.
    Thanks. That app helped. I'm just confused on what happened. I know it was never that loud. What changed?
adjust keypress volume on a kindle
android settings volume key press
google nexus lock volume
keypress volume control android stackoverflow
