Calling Problem
This is a discussion on Calling Problem within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; i have facing a problem that is turning out embarssing for me.when i make a call i can hear, but the person across on the ...
Thread: Calling Problem
    Junior Member rmelco's Avatar
    Calling Problem
    i have facing a problem that is turning out embarssing for me.when i make a call i can hear, but the person across on the line cannot. for some reason, the mic? software or whatever does not work.
    when i recive a call its perfectly ok .
    i request you to please help .
    android version.2.2.1
    build no.FRG3D
    Kernel version.2.6.32.9g6624e39
    htc-kernel@and 18-2#1
    Android Lurker iPeck's Avatar
    Laval, Qc
    I had the same issue with my bluetooth mic. Since i flashed another rom, works fine
    Great...........
    Thanks for you help ,which of the rom u feel would be the best bet to solve this
    Work around... Mute and unmute, worked for me when I was pure
    Laval, Qc
    I simply flashed 2.2 stock rom (took 5 mins). I was on videotron tweaked 2.2 craprom.
    The mute unmute method might work though.
