phone won't start
This is a discussion on phone won't start within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; thanks, it worked but i tried to turn off my phone and i had to repeat the whole proccess of wiping it and like getting ...
Results 11 to 20 of 26
Thread: phone won't start
    Junior Member aliwallie's Avatar
    thanks, it worked but i tried to turn off my phone and i had to repeat the whole proccess of wiping it and like getting everything back, will i have to do that from now on?
    That shouldn't happen.
    What do you mean by getting everything back? Maybe something you're restoring is causing the problem. Try wiping again, and see if it will reboot a few times before you try and restore anything...
    If that doesn't help, flashing a new image is probably your next step...
    Is the phone rooted?
    idk i dont really know much bout phones, didnt know much of this stuff til like 2 weeks ago, thanks a lot for ur help, im just glad my phone is working again
    Are you fully working, or still having some problems?
    i think im good, thanks for all ur help
    Junior Member Rapahel's Avatar
    Phone wont start
    My nexus one just shut off on me. I can get a full charge but when i try to turn it on it jsut vibrates 7 times and then gets stuck at the :nexusx: logo . Need help. Iv tried booting into recovery didnt work. Any ideas ? Is there a way to re-install a stock rom without a sd-card ?
    No unfortunatly you cannot flash a ROM without an SD card but may I ask why you can't use the SD card just pop it into an SD card reader or another phone if you have one then your good to fash it with the passimg method.
    Phone wont start
    k. i think i have an sd card . How do i do the passimg method ? could you please give me a link to the steps for the newest version . Thanks in advance :nexusx:
    Ok well to do the passimg method you will need to be able to access bootloader which means that when you power on the phone hold down the volume down button and tell me if you see a screen with 3 skateboarding androids.
    Yes i see it ! What next ?
andriod phone wont start
android hone wont start
android phone just wont start
android phone won't start
android phone wont start
android phone wont startup
android won't start phone
googlephone nexus one don't start
my andriod phone wont start
my android phone won't start?
my android phone wont start
my nexus 7 stays at colors moving wont stratt
nexus 4 wont start
nexus s wont start
nexus4 wont start
