phone won't start
This is a discussion on phone won't start within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; That is good that means the you can use the passimg method to flash a new stock ROM to the phone you will need to ...
Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: phone won't start
  1. #21
    That is good that means the you can use the passimg method to flash a new stock ROM to the phone you will need to power back down I just wanted to make sure that you could still access bootloader. To do the passimg method download this file and name it passimg.zip then place it on the root of your SD card (not in any folders).
  2. #22
    Junior Member Rapahel's Avatar
    K. done . What do i do next ?
  3. #23
    Now obviusly you put the SD card back in the phone then all you need to do is boot up into bootloader and if you did everything corectly the phone will prompt you to flash the new file accept then let it do it's thing and your good to go.
  4. #24
    K im gonna give it a try
  5. #25
    K . so it works till the nexus :nexusx: sign then vibrates 7 times and is stuck :/
  6. #26
    Ok but when you did the flash of the stock ROM did you do you watch it go and check for any error messages because if it said anything about it failing then that is the problem. Although if it didin't this is very strange because that should fix pretty much any problem you have with the ROM.
andriod phone wont start
android hone wont start
android phone just wont start
android phone won't start
android phone wont start
android phone wont startup
android won't start phone
googlephone nexus one don't start
my andriod phone wont start
my android phone won't start?
my android phone wont start
my nexus 7 stays at colors moving wont stratt
nexus 4 wont start
nexus s wont start
nexus4 wont start
