phone won't start
This is a discussion on phone won't start within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; my phone won't start, it can turn on but it never gets past the picture with the swirling colors. it just started one day after ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: phone won't start
    Junior Member aliwallie's Avatar
    Unhappy phone won't start
    my phone won't start, it can turn on but it never gets past the picture with the swirling colors. it just started one day after i turned off my phone the night before. please help.
    Boot into recovery, and wipe cache and dalvik. If that doesn't work, you may have to wipe data, too...
    i tried it but it didnt work, any other suggestions?
    Can you get into the bootloader?
    yeah i can
    Well, that's a start, how about recovery?
    i can get into everything, its just that when i actually start the phone it stays in the part with the swirling colors and sometimes it will lag a bit then start all over, it just repeats that process over and over
    Just do a full wipe our factory reset, and you'll be fine. You're gonna lose your data and settings though...
    so just wipe everything?
    That's usually a quick fix.
    If a phone starts to lock up for no reason, it's probably just bad data from an app or something.
    Unfortunately, since you don't know which app, or whatever, then you'll be better just doing a full wipe...
andriod phone wont start
android hone wont start
android phone just wont start
android phone won't start
android phone wont start
android phone wont startup
android won't start phone
googlephone nexus one don't start
my andriod phone wont start
my android phone won't start?
my android phone wont start
my nexus 7 stays at colors moving wont stratt
nexus 4 wont start
nexus s wont start
nexus4 wont start
