Blinking Red & Green Light
This is a discussion on Blinking Red & Green Light within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello, just today I tried to turn on my phone and the screen doesn't work and there's green and red light blinking on the top ...
Results 1 to 10 of 11
Thread: Blinking Red & Green Light
    Junior Member Richdhong's Avatar
    Hello, just today I tried to turn on my phone and the screen doesn't work and there's green and red light blinking on the top right corner... Is my phone dead?
    I don't know what to do and I can't afford a new phone . Can any body help me?
    Android Lurker iPeck's Avatar
    Laval, Qc
    • Pull the battery out, replace it and reboot.
    • Try to hold vol - while powering your phone and choose reboot.
    • If it's not working, maybe its a rom issue. Did you flashed a new rom to your phone ? Maybe the install went wrong.
    • If not, I would try the passimg method to reinstall a rom.
    I hold the power button while putting the battery in. I'll have to try your method next time.
    I'm a little un-nerved by this ipeck. It happens nearly every time I remove the battery. I have two batteries and another phone (fender mytouch, which I'm trying to get Froyo OTA on) so I'm removing the battery at least once every couple of days. Maybe I need to reinstal cyanogenMod 6.1?
    Laval, Qc
    At this point, I would reinstall a rom, yes. Unless someone comes up with a better solution..
    But reinstalling a rom is no big deal. Did you make a backup ?
    I backed up everything prior to rooting. Cyanogen? No. I'm using ROM Manager to get the ROM rather than flashing it.
    Btw. I tried your way and it didn't seem work.
    Thanks for the advice. downloading Cyanogen 6.1.1 again backing up my existing version and doing it over again.
    Thanks again ipeck. That did the trick. Now i get to play around with the settings and dl the old apps all aver again! In some way s fun, in some ways... bleh!
    Laval, Qc
    I kinda like having a fresh start from time to time. Feel the breeze of change (i wont say wind, i dont want to get sued lol) although, yes, it's a little long going tru the settings.
    *Posted from my sweet Nexus One
    Don't you have backups in titanium?
    Ok. It worked once. Now it's doing it again.
android flaahing green
android flashing green light
android nexus 5 red light
green blinking light on nexus 5
green blinking light on nexus phone
green light nexus 6
htc nexus one flashing red light dead solution
lg motion wont power on just lights blink wrong rom flashed
nexus 4 green blinking light
nexus 4 green light
nexus 5 green light
nexus 5 green oed
nexus 5 red light blinking
nexus flashing.2 green lights
nexus green light flashes
