Not connecting to mobile network
This is a discussion on Not connecting to mobile network within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi I recently rooted my nexus one , to CM7 night builds , it worked perfectly for a week then from yesterday it's not able ...
Results 1 to 10 of 10
Thread: Not connecting to mobile network
    Junior Member varma111's Avatar
    Hi
    I recently rooted my nexus one , to CM7 night builds , it worked perfectly for a week then from yesterday it's not able to connect to mobile network, it's able to connect to wifi , i changed the sim to other mobile , sim is working fine , then i went back to nexus stock version FRF91 , still i am finding the same issue, i don't know what happened to my device, i am new to rooting, i appreciate any kind of help.
    Thanks
    ravi
    Android Lurker iPeck's Avatar
    Laval, Qc
    Have you checked your mobile networks and APN settings ?
    somehow i got my connection back , when i went back to stock ROM , initially it didn't find the connectivity , i left it like that and later when i saw it's started working again, i will give one more try, i like cyanogen ROM
    Thanks
    Ravi
    Well did you try what ipeck said because that is probably what the phone did it just went down to check for the apn name and conected to the network.
    Junior Member justanotherguy's Avatar
    Ok
    My N1 went and did this today. I have Tmo...
    "Mobile network not available"
    What the heck happened??? I wasnt monkeying around with anything, I just picked it up and poof, it was like that. tried the battery, the sim card etc etc..
    I got nothing! Wierd to be phone/textless for so long..
    Any ideas on what kind of settings to check??
    Thanks
    TOny
    Senior Member 40ftcobb's Avatar
    Ya apn I have to re-enter my apn everytime I flash a new rom,if I'm flashing a backup it save automatically
    Quote Originally Posted by 40ftcobb View Post
    The APN? Hm I am on a stock phone, where do I find an APN #?
    I did have it try to 'search for network' only to get an error.
    They wanted me to swap SIM cards with my wife's RIZR. My SIM didnt work in her phone, however her SIM did not work in my phone either...
    Tony
    Laval, Qc
    Apn is loacated here : ----settings----wireless and networks----mobile network----access point name
    Thanks
    I was playing around in that menu, nothing happened. Tmo replaced the SIM, all is well
    Laval, Qc
    Glad to hear its been resolved
android not connecting to network
android phone mobile network staying on connecting
cm7 mobile network not available
cyanogenmod 7 mobile network not available
cyanogenmod mobile network not available
ellipsis 7 mobile not connecting to network
my s4 isn't connecting to mobile networks
nexus 4 isn't connecting to network
nexus 4 not connecting to mobile network
nexus 4 will not connect to network in home
nexus 5 not connecting to any mobile network
nexus 5 not connecting to mobile network
oneplus one not connecting to mobile network
phone is not connecting to available mobile networks
