Battery Drain...Revisited
This is a discussion on Battery Drain...Revisited within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; As many of you know, I've rooted and am running Cyanogen 6.1.1. My battery drains much more rapidly than when running Stock. When I check ...
Thread: Battery Drain...Revisited
    As many of you know, I've rooted and am running Cyanogen 6.1.1. My battery drains much more rapidly than when running Stock. When I check the Battery drain everything seems normal...I think. An example would be, right now:
    Display 52%
    Android System 22%
    CM Updater 12%
    etc.
    Do those seem normal? I've had only about 5 min of calls, so that is way down. What concerns me is the updater. Sometimes it's as high as 18% and the android system shouldn't be that high should it? I have listened to some music, surfed a little, have tethered for about 3 1/2 hours and checked engadget a few times, but those two were higher before I tethered.
    It seems to me that cyanogen is creating some problems. I unregistered the updater and it has dropped since then.
    Android Lurker bellator7's Avatar
    EV NYC
    Is this normal? Name:  uploadfromtaptalk1297770435547.jpg
    EV NYC
    Sorry, this:Name:  uploadfromtaptalk1297770539370.jpg
    Well. Today it totally freaked out on me. Android system is just devouring my battery. I had to use my task manager :-(
    Went through and uninstalled all of the apps but a couple that I've downloaded lately...still doing it. Maybe it's the SiMi Folder and clock widget I'm trying out. Thought they'd be good since they were recommended by a Nexus One Forum devotee!
    Bellator7. That looks like you've had the display on for an hour and 14 minutes! Just curious. What was your % at the time? Also. how did you take the screen shot?
    EV NYC
    Hey dude, yes, I was using the phone's Internet features, as I do all day every day (recharging constantly of course). That's why I paid the $500 for the phone and am paying T-Mobile $100/mo for the bandwidth. ; )
    You can get "Screenshot It" on Market. Very cool. : )
