I'm having a problem with my Nexus One 'it stucks/shuts down Randomly!'
This is a discussion on I'm having a problem with my Nexus One 'it stucks/shuts down Randomly!' within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello. I'm new here, and I'd like some help. Sometimes, my phone stucks. and/or shuts down. Like I'm doing something sometimes it stucks I lock ...
Thread: I'm having a problem with my Nexus One 'it stucks/shuts down Randomly!'
    Junior Member aqeelooo's Avatar
    Hello.
    Sometimes, my phone stucks. and/or shuts down. Like I'm doing something sometimes it stucks I lock it and when I try to unlock it. The screen stays black. I let the device as it is for a while. Then Try to unlock it again in 10 minutes, doesnt work. Only solution is to remove the battery and put it again.
    I'm afraid this action is damaging my phone 'putting in and out the battery' for three or four times a day. It's really annoying.
    I don't know if it's a program that's causing all this. I ran AVG on it and everything seems fine.
    Sometimes the screen stucks and then goes back to normal after 10 - 20 secs and sometimes it doesnt even go back to normal stays as it is. STUCK, if I let it open. the phone starts to get HOTTER and HOTTER so only thing I can do is remove the battery and put it in again.
    I put my phone alot in the USB, I let it there for alot of time. I don't usuallly charge it normally with the battery-charger.
    I hope I get some answers. Thank you
    Download a log cat from the market, and look through the results. Depending on which log car you use, the errors will be highlighted, and/or you can filter by severity level...
    That should help in isolating the problem.
nexus one shuts down
