Nexus One won't connect to computer.
This is a discussion on Nexus One won't connect to computer. within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; hmmm. this whole concept of usb device driver is confusing to me. under device mgr I see over 10 lines of device driver - generic ...
Results 11 to 17 of 17
Thread: Nexus One won't connect to computer.
    Junior Member mvmcali's Avatar
    - generic usb hub
    - Intel xxx USB Universal Host controller xxx (about 6 of these!)
    - USB root hub (about 5 of these!)
    - USB mass storage device
    the last one has a yellow exclamation mark
    I deleted it as you said and then reattached the nexus one.
    the PC detected new hardware and even showed 'nexus one'
    I let windows pick the best driver and then it said there is a problem with the new hardware.
    the driver it picked is 5.1.2600.0 from 7/1/2001 !
    does it seem odd that they never updated the device driver since then!?!?
    MY assumption, from searching the web. is that there is not a specific driver for the nexus one. as that is the whole point... you are supposed to be able to plug any storage device in and it should be universally readable.
    is that right?
    That's the same driver I have, so I guess it must be right...
    I suggest trying with a different cable, to see if that's the problem?
    Junior Member nilesh1985's Avatar
    Jun 2011
    First of all go to settings->applications->enable unknown sources(if you want to install third party apps)
    scroll down and select development -> Enable usb debugging
    Now try to connect your phone using usb to computer...
    if it shows unrecognized device or driver problem....
    goto device manager select device and update the drivers..
    link to latest drivers for the nexus one downloaded with android sdk as on june 27, 2011 is
    Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu
    once downloaded extract the drivers before use..
    Senior Member 40ftcobb's Avatar
    Lol I just got this figured out like to days ago.it wouldn't work for me because I was opening the the folder "USB driver" and selecting the sub folders one by one.
    Figured out if I delete nexus from device manager,reconnect it then simply select manually instal drivers. And just click on USB driver folder and let windows do the reset it worked perfectly.
    I thought I'd already suggested that?
    Yep you did,that's how I figured it out lol,thanks dr lol
    Junior Member xavier763's Avatar
    Apr 2012
    New Driver Needed
how to connect htc nexus one to pc
mount nexus s to computer
my nexus mod manager wont connect to site
nexus 1 wont connect to pc
nexus 10 wont connect to xp
nexus 7 doesnt connect to pc
nexus 7 won't connect to pc
nexus 7 wont connect to computer
nexus 7 wont hook up to compter
nexus connects to nexus wont read cxdm
nexus htc one wont connect to pc
nexus one cannot connect to pc
nexus one won't connect to pc
nexus one wont ask to mount usb
why doesnt my google nexus connect to pc anymore
