Battery not lasting overnight after recent restore
This is a discussion on Battery not lasting overnight after recent restore within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I did a system wipe and restore to out of the box last week and since then twice my battery has died over night. I ...
Thread: Battery not lasting overnight after recent restore
    I did a system wipe and restore to out of the box last week and since then twice my battery has died over night. I am thinking maybe that something went amiss with the system reload.
    The two times it died, I was not able to check the "what has been using the battery" section as the phone had died and wouldn't turn on.
    Checking this battery use since the first time it died over night, I have seen the biggest users in the "what has been using battery" section list Android System and Phone Idle. Does this seem normal?
    Do you think I should do another system wipe and restore?
    Member jmejiaa's Avatar
    Def not normal, I've seen sometimes I get a txt message and my screen doesn't go to sleep for some reason.
    Maybe this is happening to you? Something is waking up the screen and not letting it sleep?
    I haven't seen my screen on when not being used. Thanks for that reminder, I checked the screen and it is set to auto turn off after 30 seconds.
    What kind of apps do you have installed? How is the signal when you are home? Are you having trouble keeping a signal?
    GPS off? Maybe something keeps polling for a location while you are indoors?
    I just leave my phone plugged in all night.
    My room has lousy cell signal, that might be it, but this dieing overnight is new. I didn't change any of the apps installed.
    I have installed
    Facebook - update was every hour, I changed it to never now.
    Adobe
    Angry Birds
    Antivirus
    Astro
    Barcode Scanner
    Bubbles
    Car Home
    Chrome to Phone classic Simon Free
    Color Note - with a widget on the home screen
    English for Smart Keyboard
    FlashLight
    Folder Organizer
    Gmail
    Goggles
    Google Search
    Google Sky Map
    Handcent
    iHear Network - I haven't used this since the last wipe and restore
    LauncherPro
    Maps
    market
    Moon Phase
    Munchy Solitaire Lite
    Quick Profiles Pro
    Quick Profiles
    SDrescan
    Smart Keyboard Pro
    SMS Backup+
    Swype Installer
    Swype
    Tasks
    Touch! 4Kids
    Tricorder
    TwoTouch Timer Free
    Voice Search
    WireGoggles
