Port Forwarding
This is a discussion on Port Forwarding within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hey, I'm running Cyanogen 6 on the Nexus One. I'm trying to set up some port forwarding on my laptop over the phones wifi. Is ...
Thread: Port Forwarding
    Junior Member Costo's Avatar
    Port Forwarding
    Is it possible?
    What exactly are you trying to do?
    Member fahdbhatti's Avatar
    port forwarding is only available on routers and some access points this feature is not available on your nexus one phone because your phone WLAN card is only sharing your normal connection with your PC it is not filtering it nor it has any firewall to block your incoming traffic that why you don't need to port forward from your phone because its not affecting/modifying your incoming data.
    hope this solves your problem
    Junior Member bherbst's Avatar
    The provider 3 in Austria gives you public IPs. However, such public IP is protected by the provider by default so that no connections from outside may reach your device. However on the provider website you may uncheck this. It may take some days for them to make this change to take effect but it will allow you to have a mobile server. I tested this using some IP Webcam. It works fine.
    If you want to access a host that is located in your tethered subnet it makes sense to use some kind of Port Forwarder app. For example https://market.android.com/details?id=at.bherbst.net allows you to forward a port to a device in your local subnet that you created using any tethering method.
android port forwarding
android wlan putty
forward porting phone
galaxy nexus port forwarding
how set port foward on android
how to do port forwarding ssh android
how to port forward an android tablet
how to port forward android tablet
how to port forward my galxey tab
how to port forward samsung tab 2
how to portfword a tablet
port forwarding android access point
port forwarding droid razr
port forwarding on galaxy s4
portforwarding for tablets
