help: phone turns on and off repeatly
This is a discussion on help: phone turns on and off repeatly within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; my phone ran out of battery and was dead for about 5 hours, i got it charged and everything seemed okay but until i found ...
Thread: help: phone turns on and off repeatly
    Junior Member tonyvang's Avatar
    my phone ran out of battery and was dead for about 5 hours, i got it charged and everything seemed okay but until i found out that i wasn't receiving any text messages and i couldnt get into the android market app anymore so i rebooted the phone and now all it does is turns on and off over and over until the batter dies.
    also, said i was low on memory but i uninstalled a bunch of apps and then the phone would turn off and back on and all the apps i uninstalled were still installed
    I'd suggest booting it up in Safe mode and do a system wipe and see if that doesn't fix it for you.
    yea tried doing that too, now all its stuck on that loading screen with the "X" and it just keeps doing that until it runs out of battery, so i'm just gonna call customer support
    good luck with your repair.
google nexus keeps turning on & off
google nexus one turns on and off by itself how do i fix it
google nexus phone on and off by itself
my nexus 7 keeps switching itself off
nexus s keeps turning off
nexus s turns on and off
nexus turning on and off bug
what do you do if a nexus 7 keeps on turning off
why does my google nexus one keep turning off
why does my htc nexus one keeps turning on and off
why does nexus 7 keep turning off
