Proximity sensor Issues
This is a discussion on Proximity sensor Issues within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hello i found out my N1 Proximity sensor have issue wen a install 2.3.3 my screen shutoff when i do call and stuck blank screen ...
Thread: Proximity sensor Issues
    Junior Member sirconsole's Avatar
    Question Proximity sensor Issues
    Hello i found out my N1 Proximity sensor have issue wen a install 2.3.3 my screen shutoff when i do call and stuck blank screen i have to remove the battery and put the back.
    i download Elixir App and doing some test and Sensor only Say "NEAR" I put my hand on the screen still say Near...
    Info:
    Name: CM3602 Short Distance Proximity Sensor with Ambient Light Sensor
    Vendor: Capella Microsystems
    Version:1
    Power: 0.5 mA
    /etc/permissions
    android.hardware.sensor.proximity.xml
    android.hardware.sensor.light.xml
    /system/lib
    libssensorservice.so
    Factory Code Nexus One
    #*#0588#*#* Proximity sensor test (no work in my N1)
    can i restart the sensor?
    can i disable Proximity in DIAL ?
    do i need to take HTC Support N1?
    where is the CM3602 on N1?
    can i fix my self?
    14 times
    You might have better luck at XDA
    Nexus One - xda-developers
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    i post already there no one reply.
3602 proximity sensor
cm 10.1 razrm proximity detector not working
cm 3602 proximity sensor
cm3602
disable light sensor nexus 4
disable proximity sensor cm11
disable proximity sensor nexus 4
fixing droid dna proximity sensor
how to test proximity sensor of droid razr
how to turn off proximity sensor on cm 10.1
htc one proximity sensors issues
libssensorservice.so download
nexus s proximity sensor disabling
problems with capella microsystems cm 3602 proximity sensor
