Scandinavian keybord problem after Gingerbread update
This is a discussion on Scandinavian keybord problem after Gingerbread update within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi All Can anybody assist? After the gingerbread update this morning my Scandinavian keyboard does not work. I have tried everything but when I choose ...
Thread: Scandinavian keybord problem after Gingerbread update
    Junior Member Ben_1's Avatar
    Hi All
    Can anybody assist?
    I have tried everything but when I choose the Scandinavian keyboard as input method, then I get force close.
    It only works when I choose android keyboard.
    No so handy when you live in Denmark.
    Can anybody help?
    Thx.
    Ben
    Have you tried clearing data from the apk?
    From home screen:
    Menu> settings> applications> manage applications> select the all tab, find Android Keyboard, and clear data...
    You may lose any words that you've added to the dictionary...
    Yes I did
    Hi
    Yes I did.
    I checked the Scandinavian keyboard app and it does not really work on Gingerbread, only on Froyo.
    So I have to wait until they fix it and use Swiftkey for the moment.
    This way I can just switch between keyboards.
    I have to live with this I guess for the moment.
