Downgrade from Gingerbread to Froyo possible?
This is a discussion on Downgrade from Gingerbread to Froyo possible? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Unfortunately, there is no "now what". Your options are to either stay as you are, unlock your bootloader, or wait got an alternative method to ...
Results 11 to 20 of 21
Thread: Downgrade from Gingerbread to Froyo possible?
    Your options are to either stay as you are, unlock your bootloader, or wait got an alternative method to be released...
    Member MouseIDT's Avatar
    My bootloader is unlocked what are my options
    Install a custom recovery through fastboot, and then you can do whatever you want, including rooting your current setup (so you can backup all your data, etc).
    Do you know how to use fastboot?
    No im not familiar w/ fastboot although i see it in my bootloader I downloaded recovery-ra-passion-.2.2.1.img but dont know what to do w it
    Take a look at the first post in this thread, and set up your pc. You can then confirm connection by typing "fastboot devices"...
    http://www.nexusoneforum.net/forum/n...e-windows.html
    Junior Member cardsharp234's Avatar
    Ok so I know this isn't the exact thread that I need to be posting in (because my phone is an Evo rather than a Nexus) but my issue is the exact same thing. Is it possible to follow the same steps (but a different file, one that's made for the Evo) and downgrade it to Froyo and have the HBoot showing as a version that's rootable? Again sorry for posting about my phone in the wrong thread, but its the same issue for myself.
    I'm sure you have similar options, but I wouldn't recommend trying to follow anything for a different phone. These methods vary between different versions of the same phone, so to try on a different phone is risky, to say the least...
    I would recommend asking in a forum specific to your device.
    Ok thanks. I figured that that would be the case, but also figured it couldn't hurt to ask. Appreciate your quick reply though! Well off to the correct forum I suppose!
    Wish I could help - I just don't know enough about the Evo... :/
    Oh no bud. Totally not your fault. I knew that I was posting in the wrong forum to begin with and was (i guess) hoping against hope that someone would know off hand? No fault of yours for sure.
degradar atrix 4g froyo
down grade to fryio on atrix
downgrade android version xprt
downgrade atrix to froyo
downgrade gingerbread to froyo
downgrade gingerbread to froyo captivat
downgrade nexus one to froyo
downgrade xprt froyo to gingerbread
how to downgrade to froyo
nexus one downgrade to froyo
nexus s downgrade to froyk
nexus s downgrade to froyo
