3G Problem
This is a discussion on 3G Problem within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Hi Guys, I got my N1 for more than 1 year and it was totally fine till 2 month ego. suddenly coverage bars showed no ...
Results 1 to 8 of 8
Thread: 3G Problem
    Junior Member Arash's Avatar
    3G Problem
    Hi Guys,
    suddenly coverage bars showed no coverage and written Optus (Australian network) is not available. later I realized that I could have everything in normal with "use only 2G networks" ticked. Of course I couldn't use 3G.
    I've updated to gingerbread and still has the same condition.
    Could it be from hardware failure ,for example 3G antenna is broken?
    What are your suggestions?
    Many thanks in advance.
    Using 2G data is very painful
    Android Lurker iPeck's Avatar
    Laval, Qc
    Check your access point name settings, we never know maybe they have reseted
    Hi IPECK
    Thank you for your prompt reply and very interesting suggestion.
    I checked APN and re-input it manually.
    As soon as I removed the 2G only tick, the green bars were grey and internet 3G appeared for a minute while internet was not working. Then disappeared.
    Banned Rui Sousa's Avatar
    *#*#4636#*#* and choose the first menu on top to see your 2g/3g radio settings
    Type that in your dialer, and check if you have any thing wrong in that settings. Be careful and do not touch any thing you don't understand.
    maybe you have the "gsm only" setting on, and if you choose "gsm auto" or "wcdma preferred" that should solve your problems.
    Good luck!
    Unhappy
    Hi Sousafrui,
    when I changed my preferred network type from "gsm only" to "WCDMA prefered" or "gsm auto(RPL)", run ping test failed and there wasn't any bar for coverage.
    Junior Member thebas's Avatar
    Mar 2012
    Hi ARASH
    Could you find a solution for your problem?
    I have the same from 2 month ago.
    Thanks in advance.
    Threw it away
    hi ,
    It was hardware problem (not sure)
    I've upgraded it to Galaxy Nexus.
    Good Luck
    Quote Originally Posted by thebas View Post
    Hi ARASH
    Thanks in advance.
    did try new sim card
    [SIGPIC][/SIGPIC]
    San Francisco Giants
3g settings for nexus one
google nexus 4 3g not working
