Nexus one is a brick - HELP PLEASE
This is a discussion on Nexus one is a brick - HELP PLEASE within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Originally Posted by Batman Hey guy, I could really use some help I updated to the gingerbread via the ota update a couple of days ...
Results 11 to 19 of 19
Thread: Nexus one is a brick - HELP PLEASE
    Banned Rui Sousa's Avatar
    Smile
    Quote Originally Posted by Batman View Post
    I updated to the gingerbread via the ota update a couple of days ago, was running fine
    Then today my phone suddenly went off while I was using it, when I try to boot it up, it gets to the lock screen and then it's unresponsive, completely. Can't do anything but pull out the battery.
    I rooted when I was using froyo through the superoneclick root method, I was running cyanogen but switched back to stock froyo when the OTA started going out. I tried charging it, running it in safe mode, rebooting into recovery, nothing.
    When I try to reboot into recovery it gives me the dreaded android with the triangle exclamation thing.
    PLEASE guys, I could really REALLY use some help.
    Thanks a lot
    Man out of the blue like that is really weird. I'm in the same context as you and afraid that the same happens to me.
    Didn't you made any changes in your phone before the incident? Install anything? Maybe you forgot?
    If you can't access recovery or solve the problem maybe you need a more drastic solution like flashing your rom again, after your made sure that's not a hardware problem.
    Hope everything turns right again and you can use your phone like it should be.
    Member Batman's Avatar
    I owe you one :D
    This is your life, and it's ending one minute at a time.
    All fine did as Danger rat said, data gone, but I have some old backup lying somewhere on my mac. No biggie, woot
    Sweet!
    Enjoy... xD
    Whahoooo!!!!!!
    Danger to the rescue again!
    Ah, one last problem. Titatnium backup and setcpu can't detect my root, sigh. Rebooted and no luck, any ideas?
    Did you check superuser?
    If you upgraded to a stock GB, you've lost root. That's why you had the stock recovery...
    good catch danger. I forgot he went back to stock.
brick nexus one
bricked nexus one
nexus one brick
problems with nexus 4 bricking
