Help updating to 2.3.3
This is a discussion on Help updating to 2.3.3 within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Mybackup just told me that my phone has root access. This is news to me. Should we be doing anything different? I'm just backing up ...
Results 11 to 20 of 22
Thread: Help updating to 2.3.3
    Member MrsMime's Avatar
    I'm just backing up to SD card now.
    Yes.
    If you're rooted, we can backup more stuff, so ilk keep you rooted, so you can restore more...
    I'll find a different file for you to install...
    So disregard the first file you sent?
    Also, I'm downloading the Mybackup root one instead and backing up from that. I'm guessing that would be better.
    Yes, disregard the first file.
    Yes, root version will work better...
    Also, can you download and install ROM Manager from the market...
    Download this file instead...
    http://www.mediafire.com/?9z65uzfq5i9od
    The GB stock one? Or something from the folders?
    I'm downloading the GB one.
    GB stock v20
    Okay, so now what do I do? Throw it on the root of my SD and flash through recovery menu?
    Pretty much... Make sure to wipe...
    Before you do that, I want to check which recovery you have installed. Open ROM Manager, and see what it says at the top of the screen...
    Wipe? What should I wipe, the OS? I'm not sure how to do that.
    So I installed ROM Manger's "Clockwork recovery" when it prompted me to. My "Current Recovery" is ClockworkMod 3.0.0.5.
