Help updating to 2.3.3
This is a discussion on Help updating to 2.3.3 within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; In ROM Manager, scroll to the bottom, and under All Clockwork Recoveries install 2.5.1.4 You can then use the Install ROM From SD option to ...
Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: Help updating to 2.3.3
  1. #21
    You can then use the Install ROM From SD option to install the zip you downloaded. When asked, say no to GAPPS, and yes to wipe...
  2. #22
    Member MrsMime's Avatar
    And that's it? That's GB installed, after that? Thank you so much for your help - I never would have thought to do this myself. Awesome!
