Nexus one won't boot into recovery, please help
This is a discussion on Nexus one won't boot into recovery, please help within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Would this be the right one? [Recovery] [07-Jan-2011] RA-passion-v2.2.1 - xda-developers...
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 55
Thread: Nexus one won't boot into recovery, please help
    Member kesi's Avatar
    OK, I installed that recovery image.. I hold the volume-down button during boot and select 'recovery'. It hangs at the cross again. Any other suggestions?
    I can't get to the SD card, I don't have another phone that uses micro SD or any kind of card reader. Are there any other options?
    Quote Originally Posted by kesi View Post
    Hmmmmm...
    That's looking like bad news.
    Let me think on this for a while...
    Ok, update. I unzipped the Passion-FRG33.zip image and flashed each section via fastboot (boot,system, userdata, radio). It came up. I'm not sure I trust it though... I think I'm going to flash the custom recovery and then do a nandroid backup.
    Dude, you're all over this!! xD
    Frustration and lack of smart phone can make a person learn alot. I'm terrified to upgrade to Gingerbread again. I did it manually last time and didn't wait for the OTA.. could that be the problem?
    Well it's possible that the upgrade corrupted something, but you've earned your wings in fixing it! If things go pear shaped again, you now know how to deal with it!! xD
    If you do plan on upgrading again, I would recommend using a pre-rooted ROM. You seem pretty comfortable handling the phone, so you may as well get the most out of it...?
    Awhile back I played with custom roms, but everytime an OTA update came through, I had to jump through all kinds of hoops and lose all my apps, etc. What, in particular makes it worth the custom roms and root? I'm downloading the OTA Gingerbread, and I notice it's now 2.3.3.. so maybe they patched some things.
    Custom ROM is a personal choice, but there are other advantages to having root. For me, the ability to backup and restore everything is huge! I also like the a2ext way of placing apps and data on the SD, so you can get more space, etc...
accessing google nexus 4 boot menu
google nexus 4 not turning on
my google nexus wont boot into recovery
nexus 4 boot menu
nexus 4 wont boot
nexus 4 wont boot into recovery
nexus 4 wont boot to recovery mode
nexus 7 recovery mode fails
nexus 7 won't go into recovery mode
nexus 7 wont charge or go into recovery mode
nexus 7 wont go into recovery mode to update
nexus one boot to recovery
nexus one will not go into recovery
nexus one won't boot
nexus one wont boot into recovery
