Nexus one won't boot into recovery, please help
This is a discussion on Nexus one won't boot into recovery, please help within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Well, I thought I was good but I'm having the same problem I used to have when I tried anything custom. The OTA update failed ...
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 55
Thread: Nexus one won't boot into recovery, please help
  1. #21
    Member kesi's Avatar
    Well, I thought I was good but I'm having the same problem I used to have when I tried anything custom. The OTA update failed with
    E:No signature (573 files)
    E: Verification failed
    Zip verification failed
    Zip isn't signed correctly! Installation aborted..
  2. #22
    Devil is in the details...
    If you have the patch (40+ meg), then it will only flash from stock FRG83G.
    If you have the full image (80+ meg), then it should flash over most older systems. If you flashed everything from FRG33, it should install, but if you missed anything, then it will probably abort...
    Do you have stock or custom recovery?
    Are you flashing a stock or rooted build?
  3. #23
    Custom recovery. And, I'd love a version that allowed me to store my apps on my SD card. I have 16 GB now and just ordered a 32 GB card.
  4. #24
    You need to find a rooted version if you want to run a2ext, and you should get a compatible gapps package also...
    Wipe, then flash.
    You may need to toggle signature verification from within recovery (you are running Amon Ra, right?)
  5. #25
    So, if I install a rooted version, will I have to manually install every patch or update and wait till xda has them? Is there a particular rom you can recommend and link to that has all of that? I installed
    recovery-RA-passion-v2.2.1.img seems to be cyanogen. I can change if need be.recovery-RA-passion-v2.2.1.img
  6. #26
    Depending on how "stock" the stock image is, you may be able to get away with flashing OTA updates, but doing so will lose root.
    If you want to keep your phone rooted, then you have to take responsibility for the maintenance...
    I downloaded the GRI40 OTA and rooted it myself (unlocked bootloader), so I can't recommend a rooted version, since I've never tried one...
  7. #27
    Well, I already unlocked the phone so I might as well go that route. How can I get it to accept the update?
  8. #28
    Turn signature verification off in recovery...
  9. #29
    OK, I just downloaded this, ran wipe, and turned off signature verification in recovery. I get this error:
    E: Error in /sdcard/updated.zip
    (Status 7)
  10. #30
    or rather, update.zip
    Trying a different build now.
accessing google nexus 4 boot menu
google nexus 4 not turning on
my google nexus wont boot into recovery
nexus 4 boot menu
nexus 4 wont boot
nexus 4 wont boot into recovery
nexus 4 wont boot to recovery mode
nexus 7 recovery mode fails
nexus 7 won't go into recovery mode
nexus 7 wont charge or go into recovery mode
nexus 7 wont go into recovery mode to update
nexus one boot to recovery
nexus one will not go into recovery
nexus one won't boot
nexus one wont boot into recovery
