Nexus one won't boot into recovery, please help
This is a discussion on Nexus one won't boot into recovery, please help within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; I've also partitioned the card and updated to ext4, I hope that was right....
Page 6 of 6 FirstFirst ... 456
Results 51 to 55 of 55
Thread: Nexus one won't boot into recovery, please help
  1. #51
    Member kesi's Avatar
  2. #52
    I think this will sort me out:
    Nexus One: Full Update Guide - CyanogenMod Wiki
  3. #53
    Sorry, you got my crack flashing habit all fired up again, so I just flashed the latest nightly...
    FYI - Biggest stumbling block for most people when flashing CM seems to be making sure you have a compatible gapps package...
  4. #54
    Ok, CM-7 seems to be working well though it takes some getting used to. Trackball wake is working too. Now I used have to figure out how to make a shortcut to turn the display off. I've been playing with tasker and I'm sure there's some way like I did in Widget Locker. How do you handle it? (Thanks again!)
  5. #55
    You can use the power widgets in the notifications bar. Cyanogenmod Settings> Interface Settings> Notification...
accessing google nexus 4 boot menu
google nexus 4 not turning on
my google nexus wont boot into recovery
nexus 4 boot menu
nexus 4 wont boot
nexus 4 wont boot into recovery
nexus 4 wont boot to recovery mode
nexus 7 recovery mode fails
nexus 7 won't go into recovery mode
nexus 7 wont charge or go into recovery mode
nexus 7 wont go into recovery mode to update
nexus one boot to recovery
nexus one will not go into recovery
nexus one won't boot
nexus one wont boot into recovery
