Nexus one won't boot into recovery, please help
This is a discussion on Nexus one won't boot into recovery, please help within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Since Gingerbread upgrade, I have had many serious problems including core Android processes crashing regularly. The most recent time it crashed, I couldn't access any ...
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: Nexus one won't boot into recovery, please help
    Member kesi's Avatar
    The most recent time it crashed, I couldn't access any of the apps, even the stock ones. So I decided to do a restore. I was able to get into recovery and reapplied update.zip. I got a message that it failed.
    So, I decided to do a factory reset and selected "clear storage" from the first boot menu. Now it just hangs on the screen with the cross. If I take the battery out and try to get into recovery, it does the same thing. What do I do?
    I think you best options are:
    1 - return to HTC (if you're still under warranty?)
    2 - unlock bootloader (may void warranty)
    3 - use passimg method to get back to FRG33
    Personally, I would go with the passimg...
    I am trying to unlock bootloader.. fastboot is not seeing my device. Any chance you can talk me through this?
    or send me directions for using passimg
    Gotta run for a couple of hours...
    Take a look at the guide I wrote, and I'll help out when I get back...
    I don't mean to be an idiot, but where can I find this guide? I clicked on the links below your prof and looked at your prof and I don't see one.
    Ok, I think I found your guide. However, I can't access my SD card. I can't get the phone to boot.. Is there any way around this?
    You can put your SD into a card reader, or another phone?
    OK, bootloader unlocked via fastboot. Trying to figure out what to do next.
    You need to flash a custom recovery...
accessing google nexus 4 boot menu
google nexus 4 not turning on
my google nexus wont boot into recovery
nexus 4 boot menu
nexus 4 wont boot
nexus 4 wont boot into recovery
nexus 4 wont boot to recovery mode
nexus 7 recovery mode fails
nexus 7 won't go into recovery mode
nexus 7 wont charge or go into recovery mode
nexus 7 wont go into recovery mode to update
nexus one boot to recovery
nexus one will not go into recovery
nexus one won't boot
nexus one wont boot into recovery
