GPS problem since 2.3.3
This is a discussion on GPS problem since 2.3.3 within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Well i couldn't see anyone else with that problem in those forum... Since update i can't open my ''Mode voiture'' (sorry for the french) which ...
Thread: GPS problem since 2.3.3
    Junior Member Fyder's Avatar
    Since update i can't open my ''Mode voiture'' (sorry for the french) which is from my free tanslation ''car mode'', basically my gps. It's icon is the same as the market now instead of a steering wheel as usual and can't open it.... when i try a msg say '' this application is not installed on your phone''
    Well since this app was there with the phone and not from the market, i don't know what to do to make it work again...Any idea?
    Metro Atlanta
    53 times
    Try this--create a new shortcut to it. Start by long pressing a blank area on the home screen, then select shortcut, then Applications. Scroll down the Apps list until you find the one you want, and tap it. This will put a new shortcut on that screen, and hopefully that works. If it does, you can just remove the 'bad' shortcut.
    In fact, can you open it from the App drawer?
    awesome it worked!, thnx!
    Metro Atlanta
    53 times
    w00t!
android 2.3.3 gps fix
gps problems with androi 2.3
