Random signal drops.
This is a discussion on Random signal drops. within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Every now and then, about once an hour actually, my phone drop its signal. The wifi and signal bar will turn from green to grey ...
Thread: Random signal drops.
    Junior Member Jack Archer's Avatar
    Every now and then, about once an hour actually, my phone drop its signal. The wifi and signal bar will turn from green to grey for a few minutes. It only does this when Im on wifi. Any reason why it does this?
    Gingerbread if that helps.
    The green signifies connection with the Google servers. Dropping to grey just means you're not syncing, or checking in, or whatever...
    Ah. Ok thanks. was wondering why it would do that. It would be grey but yet I would still have a connection. Thanks for clearing that up.
galaxy s4 mini signal bars gray or green
