OEM wall charger won't charge, but OEM usb cable does
This is a discussion on OEM wall charger won't charge, but OEM usb cable does within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; Is it possible for something to break inside of the wall charger port? It seems very unlikely, but the charger won't charge my Nexus One ...
Thread: OEM wall charger won't charge, but OEM usb cable does
    Junior Member emm3tt's Avatar
    Is it possible for something to break inside of the wall charger port? It seems very unlikely, but the charger won't charge my Nexus One or a Verizon phone I have, however the USB cable will. Any thoughts?
    Your AC charger is broken just buy a new one any AC to micro usb cable will do the trick or you could just get an AC adapter and then plug in the usb cable to it.
  1. How to silence ringers when on a call
    Last Post: 12-27-2010, 11:46 AM
problems with charger on nexus
