Phone not connecting to data
This is a discussion on Phone not connecting to data within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; So I wake up this morning and had to go to the bank. I get everything ready, get in my car and turn my wifi ...
Thread: Phone not connecting to data
    Junior Member Jack Archer's Avatar
    Exclamation Phone not connecting to data
    So I wake up this morning and had to go to the bank. I get everything ready, get in my car and turn my wifi off for the 3g so I can listen to Pandora uninterrupted. After a couple of minutes I notice that I have no 3g and the signal bar is grey. I restart my phone. Still nothing. So I cuss at it and rip the battery out in a fit of anger. An hour later, still nothing. Irritating as balls.
    Anyone know whats going on? AT&T if that helps.
    EDIT: Tried my SIM card on my old phone and it still didnt connect. Showed 3G, but when I went to go to the browser to see if it works, it still said no and denied me my internet. So Im wondering if its just on AT&Ts side today? Or just my whole plan got cut off or something?
    And now as my Nexus turns back on it shows I have no SIM card installed. Just checked and its in.
    14 times
    Sounds like a signal issue to me. Not a phone issue.
    [PHONE] Nexus 4
    [ROM] CM11 Nightlies
    [TABLET] Nexus 7
    Thats good to hear thats its most likely not phone side. I guess Ill have to go to an AT&T store to get it looked at soon.
    As I have no signal Im just imagining hundreds of people trying to text me or call me or something...
    Found out what the issue was. Turns out AT&T got the check for the phone bill, but for some reason they didnt register it. So after a quick call it was back up and running. Except on my phone. No SIM card was being detected, so I switched it to my old phone to see if maybe the card was just plain dead. Nope. Nothing. Switched back to my Nexus as I can at least get some use out of it. Then for some reason something told me to turn the SIM card the other way. Turns out I had it backwards after the service was connected again.
    So stupidity on AT&Ts side and a whole lot on my side... Nothing with the phone.
    Android Lurker iPeck's Avatar
    Laval, Qc
    Att is fast on the trigger ! Shame
andriod 5 not connecting the data
android not connecting data
can not connect my att data plan to android phone
data isnt connecting
data not connecting on android
droid phone will not connect to data
my phone is not connecting to data
phone data is on, but is not connected
phone data not connected
phone non connecting to data
phone not conecting to data plan
phone not connected to data
phone not connecting to data
phone not connecting to mobile data
rogers phone not connected to data
