Camera not working, other solutions?
This is a discussion on Camera not working, other solutions? within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; oh by the way, thanks for all the help you've provided so far you seem to be online often, each time I've replied you replied ...
Results 21 to 30 of 40
Thread: Camera not working, other solutions?
  1. #21
    Junior Member Cyclonicks's Avatar
    oh by the way, thanks for all the help you've provided so far you seem to be online often, each time I've replied you replied back quite fast :P
  2. #22
    No worries...
    I get an email on my phone every time someone responds to a thread I've posted on...
  3. #23
    Can you do me a favor with your log, and filter it down to the red and orange events?
  4. #24
    uhm.. any app or something that is ''Edit-friendly'' ?
    because at least with acatlog, it doesn'T seem easily feasible
  5. #25
    there, tried to open camera, pressed back and then this is the ''E'' lines in the logcat..
    Attached Files Attached Files
  6. #26
    Ok, looks like my phone doesn't like the file, so I'll download when I get to a computer later tonight...
  7. #27
    I've tried to format the microsd card with ''hard disk low level format tool'' and it gives a ton of format errors, I suppose the card may be the culprit..I tried the small 4gb one that came with the phone.. same issues..
    I'll go buy a new one in case it fixes the problem
  8. #28
    Gotta be worth a try...
    I'm drawing a blank - wish I could be more help!
  9. #29
    sadly still doesn't work :\
    oh well.. gotta wait for those dual or quad core phones :D
  10. #30
    Junior Member tangsta35's Avatar
    The Camera cache is stored under sdcard/android/data/com.cooliris.media...
    Thumbnails are under sdcard/DCIM/thumbnails...
    I put my SD card in my laptop and deleted the "thumbnails" and "Camera cache folder" listed above. Then I opened a command line and ran the following command:
    chkdsk /f /r F:
    (My sd card was the F drive)
    This command runs a chkdsk and fixes the errors it finds. I think I had too many corrupted files from flashing CM7 nightlies on my Evo 4G. Anyways, I'm not sure what happened, but I spent the last hour googling and the last two steps fixed it for me. What I was going to try next was to do a nandroid restore to a time when my camera was working, but I didn't need to do that.
    Try deleting those two folders and running the chkdsk command, I hope that helps.
camera not working on google nexus
camera not working on nexus one
google nexus camera not working
google nexus camera problems
google nexus one camera not working
htc google nexus one camera not working
htc google nexus one camera problem
htc nexus one camera not responding
htc nexus one camera not working
htc nexus one camera problem
nexus one camera problems
