Voicemail notification won't clear
This is a discussion on Voicemail notification won't clear within the Nexus One Tech Issues / Bug Reports forums, part of the Nexus One category; voicemail notification doesn't work now,had new sim Replaced. It doesn't show if I have a message. I check it but it won't clear....
Thread: Voicemail notification won't clear
    Junior Member Thicrae's Avatar
    Exclamation Voicemail notification won't clear
    but it won't clear.
    Welcome to T-Mobile land...I have this problem frequently. I clear it by dialing the voice mail from the notification and going through the steps of hearing "You have no messages at this time" and ending the call. If that doesn't clear it, I then power cycle the Nexus One, If that doesn't clear it, I try the check-in code *#*#2432546#*#* and then it goes away.
    Nothing has changed, it just sits there with no notification.
    Everything else works google voicemail, miss a call,
    Google text notification.
    All I can suggest is to give T-Mobile a call and talk to their tech department.
    Maybe someone else will chime in.
    nexus 1 forum response excellent always
    You guys have been great once again nexus 1 david
android voicemail and call log wont' clear
android voicemail notification wont clear
android voicemail notification wont erase
android voicemail wont clear
calllogwontclear
how to remove voicemail notification on t-mobile concord
t-mobile concord ii phone voicemail notification
t-mobile concord voicemail notification won't clear
tmobile message notification won't clear
voicemail wont clear on android
why won't a notification on android be removed
why won't the voicemail notification clear in android?
why wont my voice mail notification clear
why wont my voicemail notifications clear
